Is KleanStrip Green Muriatic Acid ok to use?
Sermovita
8
Overland Park
I have PVC gloves, but never used this before. Doesn't show percentage so I'm guessing it's low.
My pH is 8.2 so I need to lower it asap as a I have a B-Day party Saturday.
kellyfair
2,925
Tampa, FL
I looked it up... it is 20%.
As as long as it is just muriatic acid, I would guess it would be ok. But Home Depot does carry the 31%... I use that.
SpringPool
528
Spring TX
I saw this at Walmart. Here’s the sds I found. http://www.kleanstrip.com/uploads/documents/GKGM75006_SDS-903.pdf
it says >30% but doesn’t list the other ingredients. With it saying it’s low odor I would be concerned they have other stuff in it.
This one from Lowe’s lists the 2nd ingredient as water
http://pdf.lowes.com/installationguides/023857722123_install.pdf
once you add muratic acid the ph will be lowered within 30-60 min so I’d try and find something other than the green stuff.
GeorgiaPoolOwner
122
Canton, GA
The link says <30% but withholds the exact percentage as a "trade secret." It is my understanding that most of these green MA's are just a lower percentage with more water.
I asked about this not long ago here: Klean Strip Green Muriatic Acid
This is the only MA at the Walmart here, and it sells for $6.88. Home Depot sells the 31% for $9.99. A few people have said it is 20%. I have used a bottle, and that number corresponds well with the pH change in my pool. It's basically 2/3 the strength at 2/3 the costs, and it keeps me from having to make a special trip to Home Depot.
I cannot say for sure if it has anything else in it, but I went with it based on responses to my post. After 1 bottle, I've noticed no side effects. I do wish it would list exact ingredients.
SpringPool
528
Spring TX
That’s good to know. I will say if you have a pool store near by to check with them. I just bought a 2 pack for 11.99 at 30%. Last year a Walmart near us had a 2 pack of the 20% but I haven’t seen it in the pool aisle this year yet.
