Okay been doing a SLAM since the 10th. So far I have used 36 gallons of chlorine. I've seen some improvement in clarity but I still cant see the bottom in my deep end clearly and I feel the improvement has leveled off. I've continued to pass OCLT (was passing before I started). I think what might be happening is that the suspended particles are in the deep end and I don't have a MD so the filter can't really filter them. I've run my pool bot a few times and it got some debris, mostly fine silt. Today I put in the ultra fine filters and ran it and it actually looks murkier. Maybe it stirred up stuff from the bottom. One thing I noticed is when the pool bot was climbing the walls, there was a lot of what look liked fine white powder being kicked up bu the brush. I checked my calcium a while back and I have almost none (I think it was 50), but since I have fiberglass I don't need to worry about calcium, right? In any case I don't see any point in continuing to SLAM as I seriously doubt anything is left alive in there. I'm thinking to left it drift down and make sure my SWG can maintain it's original levels, which was my original problem. Assuming that is all good, there in no chlorine demand, I'm open to suggestions on how to get my water clear. I could try floccing it, since I have the robot to clean up the mess. I've always avoided it in the pas because I would have needed to vacuum to waste, but with the robot, and the fine filter, I assume it could easily clean up what sinks to the bottom. Open to any other suggestions.
