Hi guys, first of all, thank you for reading and I hope this has not been asked many times before; I did search, but did not find a direct answer to my question.
long story short, could I install an above ground pool on uneven ground if I level the frame, effectively giving a deeper end? I have this pool: SOLICE RECTANGLE METAL FRAME POOL 13′ x 22′ x 52′ – BU1322SF – Poolscape Pty Ltd
The reason I ask is because it will be very difficult and expensive to level the area I need, secondly, I'd like a deeper end if possible.
I did have this pool installed in a different spot before and ended up with sinking issues.
I prepared the area but did not put in drainage,as a result one corner sunk several inches due to wet ground from a seeping liner..
The pool stayed up with no adverse effects which makes me believe that it will be capable of supporting an even floor. (with a new liner of course.
The drop will be above 200-300mm along the long length.
If the frame is level and supported, will there be any issues?
I understand that this will cause a difference in pressure and it is not ideal, but, will it be ok?
Thanks.
Thanks.
