Hello all,
We have a 18' AGP that we are in the midst of adding a Hayward 135k BTU heater to. As a result - I need to pour a pad and relocate the pump and filter to a different spot in our yard. Im wondering if now might also be the time to add a second return fitting which would be close to the new pump pad area and almost directly across from the existing return/skimmer. If so, is it possible (or is there any reason not to) to plumb a return fitting that can act as both a vacuum port (suction) and a return via a 3 way valve?
Not sure if it matters but we have also upgraded our pump and filter to a variable speed pump and cartridge filter. I like the idea of being able to vacuum but still pull from the skimmer with the new variable speed pump.
Thoughts?
Thoughts?
