I'm currently doing the wiring for my Core 55. I'm a bit over on my sizing as I have 18-K gallon pool. There are a couple of concerns I have. 1: I may have too much chlorine at 25% output as I can only set in 1/4 increments. 2: I noticed someone else had a severe corrosion issue with their unit. Could it be that the cell continues to generate a little extra chlorine if all power shuts off at once? I'm thinking any extra chlorine buildup that stays in the cell area is causing harm if it is not flushed.
I'm thinking a separate timer would fix both possible issues or is this not an issue and overkill?
