Iron well filled please help
Richard320
23,912
San Dimas, CA (LA County)
Okay. My goal is 31. I keep it at 31 every hour until my cya lowers to normal. Is this correct. And thank you
No. CYA will not lower without water replacement or expensive reverse osmosis.
Keep at 31 FC until it passes the three tests listed in the SLAM Process article
Meaning CC is .5 or less
The water is crystal clear, even after brushing
You pass Overnight Chlorine Loss Test
All three simultaneously. Generally if the water looks good then you test CC and if it's good, you do the overnight test. If it passes, you stop adding bleach and let FC come down to where you want it. If it doesn;t pass, you bring it back to 31 and do it for another day.
Cburkett
101
Punxsutawney, Pa
Thank you for clarifying. I understand now. My cc was a 1 and it needs to lower. I'm at 31 because the cya is high. This is a little stressful and overwhelming for me but I think I'm getting it. Dont want to screw up and have to restart
Texas Splash
Hang in there. You'll get it. You have a good test kit, and now you know how to test FC accurately. You now understand what the FC/CYA Chart is used for, and you now see how the FC should match your current CYA. That's all that matters right now. Your CC may remain elevated for a while because of all the previous chemicals being eliminated, and that's okay. Testing and maintaining the FC is most important. I like to review the SLAM Process page daily just to ensure nothing is forgotten.
Cburkett
101
Punxsutawney, Pa
For regular FC testing, we prefer the 10 ML water sample. Just fill the tube to 10 ML, then add ONE heaping scoop of power. Mix and count drops until clear. Divide that number in half for your FC. Example: 14 drops equals an FC of 7.
Hello. I wanted to confirm. You gave me the 10ml water 1 heaping scoop powder counting drops and divided in 2 method. Can I still use this method when testing the cc. Does that make sense. Wanting to make sure I dont have to use the 25 MLS method when doing that.. last night I didn't do the overnight because we got tons of rain. Pool was over filled and drained it this morning. Retesting everything. Taking advantage of all rain possible now since I'm aware of what high cya is. I'll retest it to get my cya shock level again.
Cburkett
101
Punxsutawney, Pa
This morning after a hard rain last night I drained pool down to normal levels. Didnt add any more chlorine at this point. Stated to vacuum and I'm noticing a slight color change on the fiberglass. This is telling me iron staining is starting to happen. Assuming it's due to ph off balance with rain water? My husband has been on a emergency call. I only know to do the 5 drops for ph which looks high but dont know what to do next. Dont know what to do about new staining coming on. Should I add metal magic now
Cburkett
101
Punxsutawney, Pa
If
Above is right the cc was .5 this morning
Cburkett
101
Punxsutawney, Pa
Good news is since switching out so much water with rain the past few days we're at 50 cya down from 80. And chlorine this morning was 20 so for that equation we're on track.
Cburkett
101
Punxsutawney, Pa
Stains can be dealt with best after the water is clear. Just keep SLAMming.
Thanks so much for responding. I'm the least patient person in the world. With the pool water I'm trying to find my zen but its extremely difficult. The staining on the white fiberglass almost kills me. After wasting large amounts of money on products I'm trusting you guys and will follow instructions. Its pouring again here today. Will continue to keep chlorine levels up. What do you prefer for other products while I use your methods for ph and alkalinity. Again thank you
Richard320
23,912
For the staining, which you'll deal with after you pass the SLAM and chlorine levels come down, is Ascorbic Acid (Vitamin C). It works FAST. This guy tested the stains by just rubbing a Vitamin C tablet across
Texas Splash
Hang in there! Don't panic. For now, maintain the SLAM . Keep in mind that once you are in SLAM mode with an elevated FC level, the pH will "appear" to be high. This is temporary because of the increased FC level. When the SLAM is over and the FC level drops to 10 or below, the pH can be re-tested and adjusted as necessary. If your new CYA is 50, then your new FC (SLAM) level is only 20.
Cburkett
101
Punxsutawney, Pa
Thank you!
QUOTE="Richard320, post: 1629496, member: 11031"]
[/QUOTE]
Cburkett
101
Punxsutawney, Pa
Thank you. I think I may have it beat after today ? I'm vacuuming this morning and switching out my cartridge filters. I only dropped 2 points last night. The pool is looking good other than the staining. Its taking everything within me not to put metal product in. Praying tomorrow am testing will be no more than 1 loss.
Texas Splash
Progess is good. :goodjob: But continue wiht the SLAM Process instructions and focus on algae. That's very important before you begin treatmetn for staining. While you are still in SLAM-mode, here are a couple items to read ahead regarding metal staining.
Your best and most reliable method of metals management is to add sequestrant to the water and replenish it periodically. Sequestrant is a chemical that binds to the iron in the water so that it can't form stains or turn brown. Sequestrant breaks down slowly, so you need to add more regularly. ProTeam's Metal Magic and Jack's Magic the Pink Stuff (regular), the Blue Stuff (fresh plaster), and the Purple Stuff (SWG) are some of the top sequestrants. You can also find other brands with similar products, some of which are noticeably less expensive. Sequestrants based on HEDP, phosphonic acid, or phosphonic acid derivatives are the most effective.
