Iron well filled please help
Texas Splash
Does your site prefer chlorine or salt users.
Either is acceptable. Salt water generators have an up-front cost that can be a problem for some, so manually adding chlorine (regular bleach) each day becomes the routine. But in either case, it's simply a way to add/produce free chlorine. SWG's produce chlorine and bleach adds it as well. Just depends on what a pool owner wishes to do.
Richard320
22,069
San Dimas, CA (LA County)
Thank you. Does your site prefer chlorine or salt users. Since we're newly switching we're interested in either. We didn't know where to start.
There's no difference. Either the bleach is made at a factory, bottled up, shipped to a store, brought home, and finally dumped in the pool, or it's made in the pool plumbing. Same process. Same chemical. Same everything except for a few minor chemistry adjustments.
Cburkett
78
Punxsutawney, Pa
Thank you!
Cburkett
78
Punxsutawney, Pa
Hi. If I'm doing this testing correctly after my 4 gallon of bleach I'm at a 1 for fr and .6 cc I just added my 5th gallon right now at 1:30. I'm preforming by putting 25 pool water. 2 scoop powder. Brown bottle count drops until clear x's .2 for FC. then 5 drops 0003 and follow by drops of brown count until clear x's .2 ??
It's usually best to let the water circulate for about 20-30 minutes before re-testing for any chemical additions.
Cburkett
78
Punxsutawney, Pa
Ok. I'll go do nee test now. Is there a different way for cc or way I described above. Thank you
For regular FC testing, we prefer the 10 ML water sample. Just fill the tube to 10 ML, then add ONE heaping scoop of power. Mix and count drops until clear. Divide that number in half for your FC. Example: 14 drops equals an FC of 7.
Texas Splash
The CC test is done as follows:
  1. Add 5 drops of R-0003 and swirl to mix. If the sample remains clear, your CC level is zero.
  2. If the sample turns pink again, add R-0871 one drop at a time, swirling constantly and counting the number of drops as you go. Continue adding drops until the color changes to clear. The pink color may become extremely faint before it goes away. Make sure that the sample goes completely clear.
  3. Multiply the number of drops by 0.5 to get your CC level
That's from the FAS-DPD Chlorine Test - Trouble Free Pool page.
Cburkett
78
Punxsutawney, Pa
Thank you so much for the instructions. Just retested 3:30 results are 1 cc and 8.5 fc this is following adding 6 gallon bleach. I haven't tested anything else since the initial testing I gave as far as ph and alk. I would need instructions or wait on husband. I wait on what you would like me to do next.
Texas Splash
All the instructions for testing can be found here: Extended Test Kit Directions Archives - Trouble Free Pool.
If I recall, you said you didn't think you had algae correct? However a CC level of 1 is slightly elevated letting us know something excessive is being processed in the water. Remember, it's important to ensure the water has no algae before finalizing anything for iron. If you have any doubt about algae, even if you can't actually see it at this stage, you can do an Overnight Chlorine Loss Test test.
Either way, the things I would focus on at the moment are FC and pH. Make sure the pH remains fairly low in the 7.2-7.4 range which will help with the iron. If you have to do a SLAM Process for algae, you want the pH low anyways. Keep the FC balanced to your "current" CYA as noted on the FC/CYA Chart. On the non-SWG chart, find your CYA and then the matching FC level. If you have any problems, let us know.
Cburkett
78
Punxsutawney, Pa
I do not see any algae at all in the fiberglass walls. They are white and easy to see. I have had the pool uncovered though with 0 chlorine since reaching out. If you think it's best to do some testing first I'm fine with that. I so badly dont want to have any more issues. I dont know if products effect the cc. I had a ton in it. Since opening I've put at least 5 bottles of magnet plus and sparkle up. Since reaching out initially I put one bottle metal out, one bottle citrate acid and one bottle of oxide acid I think it was and a bottle of algaecide. Pool place had me putting tons and tons of shock I different times to increase chlorine.
Cburkett
78
Punxsutawney, Pa
Ill read the instructions for the over night. So that you can better help me I'll eliminate all the what ifs from the beginning.. will go ahead and do it.
Texas Splash
Yes, all of the other products added will certainly effect regular chemistry, but you can get through this. No pool should be at 0 chlorine though except under rare circumstances, and even then only for a very short period. So for now, adjust the pH lower to the 7.2-7.4 area and balance the FC with the current CYA. If you do the overnight test (Overnight Chlorine Loss Test), let us know tomorrow if you passed or not. Good luck!
Cburkett
78
Punxsutawney, Pa
Thank you! I think I already have the answer. FC has fallen to 2 will check in am but planning to get the supply to start slam in the morning. You have no idea how much this site has helped me already. I'm feeling hopeful again.
Reactions: Texas Splash
Cburkett
78
Punxsutawney, Pa
The pool lost all of the chlorine. I'll head to get the bleach and start slam this morning.
Cburkett
78
Punxsutawney, Pa
Also do I continue to leave the pool heater off during this process of slamming
Cburkett
78
Punxsutawney, Pa
I'm starting the slam process. Once I start putting the chlorine in how long to I wait to start testing. I used a calculator that said start with 4.5 gallon of the 10% chlorine
