Introduction and question about baja shelf cement curing/drying time.
cincin18
3
POWAY, CA
7CA85664-91F7-4EFB-B3FF-8B5B4FCF9EA5.jpegGreat helpful forum. We live in Poway, CA and are having our pool refurbished and adding a baja shelf. The plan is to have it 9inches deep. They poured the concrete today in the baja shelf and it approx 18ft x 7.5 ft in shallow end approx 4-5 feet deep from shallow to deep end. They did use all the demo plaster, coping excess and broken pieces, red bricks which was our old coping. The PB used rebar and drilled into the pool shell and adhesive.
I have unable to find a thread that talks about curing time . When we were receiving quotes for the redo every PB stated a different curing time form 3 days to 3 weeks.
What is the recommended curing time for this amount of cement? We are in southern California and it is forecasted to be high 80’s ( today being 90 deg) with 34% humidity.
Great to be apart of the forum.
Thank you ahead of time for your answers.
CinCin18
Killer95Stang
916
Sunny SoCal
Borrowed from google....
What is the minimum curing period for concrete?
7 days
For most concrete structures, the curing period at temperatures above 5º C (40º F) should be a minimum of 7 days or until 70% of the specified compressive or flexural strength is attained. The period can be reduced to 3 days if high early strength concrete is used and the temperature is above 10º C (50º F).
So basically, the answer is... "it depends".... A baja shelf is not really a structural part of the pool, so will it need 70% of its strength... probably not. If you they plaster next friday... then you are probably good
cincin18
3
POWAY, CA
Thank you,
We have not heard the exact date for our Hydrazzo spraying.
We were told 3-5 days by the scheduler and the concrete contractor stated 1 week. So basically with our weather hopefully next Fri would be great.
Thanks again.
