Intex xtr 18’ installation
Adf21389
1
Alexgigi312
Hi all!
I’m hoping to get some help. I just installed the intex XLR 18’ round pool. I have about 2 feet of water. It looks like some of the vertical legs are Slightly slanted.
It’s already too heavy for me to move just by lifting. Any suggestions? Should I try and shift it with a Mallot/drain it, fix the legs?
before I continue filling it up, I want to fix these legs! Has anyone had experience with this? Not sure if it will be an issue once filled if I don’t do anything about it
Thank you!
kellyfair
4,293
Tampa, FL
Intex Krystal Clear
Need to know more... are legs mounted on anything (pavers)? Can you show a photo of what you are seeing?
outpost
52
Long Island
Is the 2 feet of water at the same Checkerboard mark all the way around the pool ? If so probably can just level the legs and keep filling. If not your ground is too far off level and it’s only going to get worse.
