Intex Ultra XTR and frame rust
Transy416
Active member
Jun 22, 2013
28
Scratch the POR-15. It apparently won’t adhere well to surfaces without rust.
Any other suggestions on how to maximize the life of the frame?
Wobblerlorri
I got some Rustoleum clear sealant and coated the outside and inside of all the uprights on my pool. Didn't think to coat the cross members and tees, and I had a little rust on two cross members this year. Nothing a file and Rustoleum couldn't handle, though.
Transy416
Active member
Jun 22, 2013
28
Yes, I was also thinking of that. As an alternative, I’m also looking into coating everything with Fluid Film or Wool Wax.
I’ve read the TEES can be a problem due to the interlocking parts. Maybe the powder coating on the inner walls is helping. Do you have the XTR?
Yivv
1
Huntington Mills, PA
How far into the poles were you able to paint with the clear sealant? Does the coating create any friction issues when connecting it to the T joint? I'm thinking of doing this with a new set of poles for an Ultra Frame.
Transy416
Active member
Jun 22, 2013
28
I used a spray can and got about a third of the way up the tube. No friction issues. I wish now I'd done the cross pieces and the tees as well.
In relation to the the pool liner and where it hangs on the frame, where along the cross members are you seeing rust?
Transy416
Active member
Jun 22, 2013
28
That makes sense that it’s near the connection. I’ve read about some people wrapping all connections with silicone tape to prevent water entry.
Transy416
Active member
Jun 22, 2013
28
I received my pool and I was looking at the design of the legs. I’m a little surprised there are no weep holes in the bottom of the legs to let water out. That said, the only entry points would be through the push pins that serve to lock in the connection. Assuming this area is sealed with silicone tape, water shouldn’t get in. However, I still wonder if a weep hole at the bottom would be a good idea. On the other hand, water would also be allowed in through a weep hole.
