intex pump replacement
Jweers
5
Idaho
so, I have an intex pump / sand filter (sf60110-1). has about a 1/2 hp motor on the pump. the pump leaks at the sleeve seal and so is probably a candidate for replacement.
I called INYOpools (who helpfully tells me they don't sell anything that is in any way compatible with intex, and they tell me in such a way that I'm guessing there's an interesting story, but not a fundamental incompatibility with the pumps.
so. wondering if I get a pure line 1.5hp dual speed pump (PL1507) and run it on LOW speed, if that produces just about the right pressure and gpm to run my sand filter. low speed is around .4 hp
and then I'd just have to fab up some connectors from the new pump to the intex hoses.
can anyone confirm my thought process here?
(pool 9x19x5 intex, somewhere around 5000 gallons)
cowboycasey
7,640
Southern OK
CircuPool SJ-40
mas985
14,372
Pleasanton, CA
Intex filters are much too small for a standard AG pump not to mention it is a connection nightmare.
Reactions: Mdragger88
Jweers
5
Idaho
well... two speed above ground pump in place. on low speed it works BEAUTIFULLY... and almost silently.
the 2500 GPH intex sand filter works just fine and at a slightly lower pressure than with the intex pump.
water flow looks to be very close to the same.
I've run PVC piping to replace all the intex flexible hose. the transition between the two was super simple with a trip to Home Depot.
I got a bunch of reducer bushings like this where the intex hose collar fit and then sized the PVC for the inner diameter. a bit of sanding and it's a beautiful watertight and about $2 cost to move from intex to PVC...
mas985
14,372
Pleasanton, CA
Just don't run the pump on full speed or you could damage the filter.
cowboycasey
7,640
Southern OK
CircuPool SJ-40
Whenever the prices go down you can get a real sand filter and connect it up and use both speeds :)
