Intex Pump and Pool combo. This should be okay,right
Windwalker
3
RDU
So finally got the new 15x48 set up, after some weather and grading delays
Currently using the pump that came with it. Have had Intex in the past and always upgraded the pump
Planning to go with Sand and Saltwater on this one
Bigger pump is already set-up, waiting to add the 85# of glass and 140 pounds of salt.
The new Pump is the Intex EC021110-2(2150GPH)
Looking in the setup instructions-Intex Pools Salt Table
the combo of my pump and circular metal pool(15x48) has a hash mark(implies not suited) however there is pounds of salt number for the smaller 1600GPH pump(110#)
Never heard of possibly having too much pump- is that even a thing?
Further in the instruction manual there is a salt table for common non-intex pools, which says a 15x48 would need around 125# salts
No reason not to use this 2150GPH pump with my 15x48 pool is there?
Have already installed the larger outlet jet and will be doing a through the wall skimmer
Thanks
Texas Splash
30,375
Fiberglass
CircuPool RJ-45 Plus
Welcome to TFP! :wave: One time when you can have too much pump is if it overrated for the filter, but if you got the Intex combo I don't see that as an issue. I don't recall if that model is a 2-speed, but if it is then on low speed you are definitely fine.
Reactions: Windwalker
Windwalker
3
RDU
Thanks Splash
Single Speed, pool capacity is around 5000 gallons-which is inline with the specs for the pump
kellyfair
4,617
Tampa, FL
Intex Krystal Clear
You should be fine. I just use regular pool sand in mine.
kellyfair
4,617
Tampa, FL
Intex Krystal Clear
By the way, I would add salt in increments rather than all at once. Easier to add more than to drain because you added too much.
