I have the intex pool setup that has worked well the last few years. When i switched to pvc pipe i think i had this issue, evident from the mass amount of silicone i have around the opening in the photo (which is now even more gooped up after other attempts to stop the continuous drizzle that is coming from the edges.
I opened the pool, filling it up, so fixing may have to result in lowering the water down below this point, unless there is some magic fix that can work from this backside of the pool.
Anyone have any suggestions or ideas on what parts i should look for to fix it?
Thanks in advance
Thanks in advance
