Hi Everyone,
I moved into a home, and this is my first time having a pool and I have no knowledge other than what I've read up on so far, so I apologize in advance if my question may sound very simple.
I noticed that my timer always stops/gets stuck about 15-30 minutes before the scheduled time of the "On" timer dog and does not move after getting in this stuck position. First time I noticed it, I said "Let me move the timer dogs forward a few hours and see if it works", but the same thing happened - the clock dial did move but got stuck 15-30 minutes before the scheduled "on" timer dog. So I tried moving the timer dogs again and, again, the clock dial moved appropriately but stopped 15-30 minutes before hitting the "on" timer dog, and the clock dial stays there. The dogs are on tight and the timer was made sure that it was not "popped out" when I adjusted the clock dial previously.
The pool pump works with the manual lever turning it off/on. When I look in the little hole in the top right to check the gears, there are two little black gears and I see the back gear moving but the front one is not moving. Not sure if that has any significance. If it matters, the pool is only about 2 years old.
Does anyone know what may be causing my issue? From what I read, I may just have to replace the entire timer mechanism but thought I'd throw this out there to see if there is an easier fix.
Thank you so much for any advice!
EDIT: I have included some photos of my timer mechanism I took a while ago. Would this be the T104M that I would need to buy if I were to replace it?
