Intermatic 104R - Losing Time
malazarock
23
St Augustine Fl
Hi Guys - looking for some help with the timer that is hooked up to my SWG. I've noticed every couple days I need to adjust/correct the time. The timer is only 3 years old, could it be going bad already? Who would fix something like this, an electrician? I have been able to do a lot of things with our pool myself (with the help of this great forum), but I feel like this is a little out of my league :)
And.....when I checked this morning it was way off, and I fear the SWG came on when my pool pump was off. So I'm a little freaked that I did some damage to the SWG.
I included a picture for reference. Appreciate you guys!!
ajw22
23,655
Northern NJ
Pentair Intellichlor IC-60
The Intermatic timer should last more then 3 years. But they cannot be repaired.
Check the voltage to it with a multimeter. If the voltage is good and it loses time then replace the timer mechanism. You can buy the timer without the box and it is easy to replace. Turn off the CB and it is just a few screws.
ajw22
23,655
Northern NJ
CB = Circuit Breaker
The way you posted your pic it cannot be enlarged. Post a larger pic of the timer. What model number is on the door sticker?
