Recently, I closed our pool and left the Spa open.
I removed my SWG and replaced it with a thru pipe.
I decided to put a floater with two 3 inch CL tabs in the spa, about 4-5 days ago. (I do NOT use these regularly)
I measured CL and PH a few minutes ago using the Taylor kit that comes with the TFT-100...and when the reagents went in, WOW....
BOTH looked like Apple Juice or light coffee, which I have never seen that color.
Wow.
After shaking, the PH measured below 6.8 and the CL stayed looking like apple juice.
So, I assume those two-inch tabs really worked...CL super super high....more than I would have liked...yes?
Does this make sense....super high CL makes the OTO turn like brown apple juice?
I also noticed the smell of CL in the air, lightly.
Since I SLAM before close, I know the algae is 0. Pool water super clear.
If this is the case....I may need to drain and replace some water as we plan to use the spa tonight....I'd rather not immerse ourselves in super high CL...
Wow.
