I became curious about the whole "manual dosing" thing with the IntellipH.
The manual states that "approximately 4 oz of acid will be dispensed within the 60 seconds of the manual dosing cycle. Well, to me, that is a bit ambiguous, since the MA is normally diluted by 50%. So, it got me thinking. Is it 4 oz of solution (50% MA and 50% water) which is 2 oz of actual MA, or is it 8 oz of solution and actually 4 oz of MA.
So I removed the feed tube and tap from the plumbing, inserted a cap into the plumbing tap, and placed the feed tube into a bucket.
I then fired up the pump and actuated the manual dosing cycle.
I measured the amount of solution that was fed into the bucket. It was exactly 5 oz of solution. So, it only makes sense that a 60 second manual dosing cycle would deliver 2.5 oz of actual MA.
So now I know how much actual MA is being introduced into the pool when performing a 60 second manual dosing. I think this is beneficial information to have, especially during the winter, when occasional manual MA dosing is required and when "tracking" one's pool chemistry and chemical use.
Reading the manual, I am under the impression, that when manual dosing, the "Dispense Amount Percentage" setting is irrelevant. Can anyone actually confirm this fact? Am I to assume, that a manual dosing cycle is equivalent to a 1 hour/100% setting under the "auto mode"? The manual indicates an MA dose of 2.13 oz per hour at 100%. That would make sense if my assumptions are actually correct, but I have learned that making assumptions when it comes to interpreting Pentair documentation can be risky.
It would be great to hear from other's with similar type information or advice regarding the IntellipH, since I am still a bit of a rookie using this Acid Dispensing System.
