We have a new pool with an pentair easy touch system & intelliflow pump. While pump was running to a schedule I adjusted it on screen logic. ( from 8am-7pm to 8am-5pm.) The modified schedule still should have had the pump continue running. The pump shut off & would not respond to easy touch nor screen logic. I did receive pump comm errors in the screenlogic alert section. I tried cycling power to easytouch panel & pump with no change. i rebooted the iPhone screen logic was running on. I ran a diagnostic on the easytouch panel with no errors. I could hear a relay activating & pump light on in the easy touch panel when toggling the pump button on screenlogic app But no pump activation. I deleted the schedule & entered a new one in screenlogic. I was able to run the pump manually, but when doing so noticed the screenlogic app stated no salt when previously there was 3800. After cycling power on everything I left it alone…the next day the pump worked to the schedule, there was salt in the pool, ie everything ok.
curious if anyone else has experienced this? Is something not set up right by the installer or is this a quirk in the software or safety mechanism that shuts easytouch control down when a schedule change occurs while pump is running?
