Intelliflo running outside schedule
keene3b07
Platinum Supporter
In The Industry
May 9, 2011
175
I’ve got an intelliflo running spa jets. The jets are turned on by rotating a 20 minute switch. The customer wants the jets to not turn on after 10 pm.
I set 1 schedule in the intelliflo from 8am-10pm. However when the switch is turned on after 10pm the jets still come on. Any ideas? The clock is correct and there is 1 schedule and 2 egg timers
ajw22
37,898
Northern NJ
Pentair Intellichlor IC-60
Does that mean the power to the Intelliflo pump is controlled by the 20 minute timer?
The schedule will not prevent manual control of the pump outside of the schedule.
Or are you saying the pump automatically begins running when power is applied to the pump?
What model number IntelliFlo pump?
keene3b07
Platinum Supporter
In The Industry
May 9, 2011
175
Yes the power to the intelliflo is controlled by the 20 minute timer. The pump is running when it gets power even though it is outside its schedule. There is no manual control of the pump happening. Think of the 20 minute switch as a breaker. I don’t have the model number off hand
ajw22
37,898
Northern NJ
Pentair has made many different models of Intelliflo pumps with different drive doe.
I suspect that the pump maybe setup so that if it is running when the power is cut then it begins running when the power is restored.
Next time you are at the pump run some tests.
  • With the pump off cut the power, then turn the power on, see if the pump begins running
  • While the pump is running cut the power, then turn the power on, see if the pump begins running
There may be a setting in the pump for it should resume running when powered on. Need the model number to try and check the manual.
