Intelliflo Corrosion Issue
GEAUXHOOKEM
4
Orange County, CA
We just purchased a home in Orange County, CA last month. Of all the inspections I got done (structural, video plumbing, etc) I managed to forget to do the pool inspection. There is no one to blame but me. Aside from the cracked filter housing and other valve related issues and leaks which have been repaired since we moved in, my latest involves a Pentair VS-3050 motor that looks very much like the ones described above. Apparently, there was a very slow leak over the course of months/years that caused the motor to corrode. While the unit is still functioning I'm debating if I should replace the entire pump or just the seal plate and motor. The entire motor unit almost seems to be sitting crooked and there are a couple of corroded screws that literally just pulled out with little to no effort. I also need a new electrical whip installed as well since it isn't even locked on the threads. What say you guys/gals?
mknauss
23,555
Laughlin, NV
Welcome to the forum!
To my knowledge, the Intelliflo is sold as a complete unit. I have not seen replacement motors for that unit. Others may know differently.
The current model to get is the 011028. It is a VS only drive.
I suggest you read ABC's of Pool Water Chemistry.
Jimrahbe
15,806
Bedford, TX
G,
If this were my pool, I would replace the entire pump and motor... I have tried patching things in the past, and they will work for a while, but always seem to be a problem later... For me, my time is much more valuable than the additional cost.
I agree with Marty, I would also buy the new IntelliFlo, with the rotatable control head. P/N 011028. With a cable you can actually mount the control head on a wall.
The good news is that you had an installer that had a clue what he was doing and used unions. So it will be very easy to install a new one.
JoyfulNoise
Platinum Supporter
May 23, 2015
16,224
I think it was last year or the year before where SoCal got flooded with torrential rains. Do you know if that area of the home got flooded??
Also, check the bonding wire. Your pool, pool equipment, and anything metal within 5ft of the water should be electrically bonded with a bare copper wire. The pump should be bonded too. Bonding is not the same thing as grounding.
GEAUXHOOKEM
4
Orange County, CA
Thanks for the welcome. We just moved to Orange County from Dallas where we had a pool. I've been a lurker on TFP for years which is actually where I got my chemistry chops up and decided to become my own pool guy. The equipment side is a road I've dared not travel though. I will look into that particular model you suggested!
