Thank you very much. So since my relay port in the IntelliConnect has Line 1 In/Out and Line 2 In/Out (4 terminals), would I split the wire from the transformer to the relay to both Line 1 & Line 2 In, and then have the red and white wires coming out of the relay to the actuator? Or just have the wire from the transmitter to Line 1 In only?
Also, it appears to me that if I went this route, I could just use a wife aux relay like on of these:
Amazon.com : SHELLY 1 One Relay Switch Wireless WiFi Home Automation iOS Android Application 1 Pack : Camera & Photo
www.amazon.com
4 Channel WiFi Momentary Inching Relay Self-Lock Switch Module, DIY WiFi Garage Door Controller (5-32V) - - Amazon.com
www.amazon.com
Would that work? If so, some are advertised as "inching relays"? Would that mean I could open to different levels and perhaps use an IntelliValve to control flow?
Thanks so much in advance!
