intellichlor 40 vs ichlor 30
darinclifton
Active member
Jun 2, 2019
34
St. Louis
Hi all! We are in the final stages of our pool design and wanted to get some feedback on the SWG. Pool and Spa volume will be approximately 12k gallons. I am leaning towards the ichlor 30 but wanted to get some feedback on that vs the Ic-40. We will be using an Intellicenter for automation with intellipH. Thanks!
ajw22
21,221
Northern NJ
Pentair Intellichlor IC-60
My personal opinion is the IntelliChlor is a more robust quality SWG. You get what you pay for.
When you normalize the cost difference for the additional capacity the costs are about the same.
mknauss
33,912
Laughlin, NV
From a size standpoint either will work. From an integration with the Intellicenter, the IC40 power center can be integrated in the Intellicenter. Just be sure to purchase the Intellicenter with the SWCG package.
Th iChlor power center is separate and will connect to the Intellicenter with a data cable. So you will have an additional box on the wall.
darinclifton
Active member
Jun 2, 2019
34
St. Louis
My understanding was that the ichlor 30 can use the same power supply as the IC40? You can actually buy the load center with the IC transformer and add the ichlor separate (basically a custom "package") costs are about the same.
