IntelliChem not dosing acid
booboo
59
Marana AZ
I recently got a IntelliChem installed by a local pool company. Everything seems to work properly but it is not dispensing acid. I think they hooked it up wrong. Can someone look at this an tell me if its hooked up right. And if its not how to do it correctly. I am convinced they don't know what they are doing and if I can fix this without them, that would be better.
Here is the Intellichem.
Here is the tank and pump
They told me I did not need this , I think I do.
Here is how they hooked up the tank/pump. In the red circle.
ajw22
37,993
Northern NJ
Pentair Intellichlor IC-60
Why did you get a Pentair Intellichem when you have all Hayward equipment including the OmniLogic?
Hayward has the Sense and Dispense system that would work with your OmniLogic and SWG.
booboo
59
Marana AZ
Hayward has the Sense and Dispense system that woudl work with your OmniLogic and SWG.
I have all Pentair equipment.
mknauss
50,859
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
This is not your pool?
I moved this to Everything Else. I look at it as part of Automation. It is not a SWCG, it is not a Stenner pump chlorine dispenser.
ajw22
37,993
Northern NJ
So do I need to keep changing it depending on the pool I am askling about.
If you have two homes both with pool then concisely list equipment on both of them.
Winter home-pump, filter, etc. Summer home-pump, filter, etc.
