Hey guys,
I just had my pool installed last spring with all the components listed in my signature. After some issues this winter and just a general displeasure with how the installer set up my pad, I decided to "start over" with the pad, so I cut everything back and am now in the process of rerouting plumbing, electrical conduits, comm wires, etc. In cleaning up the Intellicenter load center, I am seeing some things that don't make sense to me (even after reading all of the wonderful guides others have posted here). I currently have an i8P setup with 8 total relays in the load center. 1 relay is powering the 3x pool lights, 1 relay is powering the 3x laminar lights, 1 relay is powering the 2x bubbler lights, and 1 relay is powering some LED wallwash landscape lights. All of that worked great last year when the pool was open, but now that I'm reworking the pad, I wanted to take advantage of the extra relays that I have with the i8P that were not currently in use to power some lights individually.
My question is in regard to the FLTR relay and perhaps AUX circuits in general. In my system, the FLTR relay is not connected at all to the motherboard and my VSF pumps are wired directly to a breaker, this setup worked fine for me last year.
Current relays are wired:
FLTR - Not connected
AUX1 - Not connected
AUX2 - Pool Lights (x3)
AUX3 - Bubbler Lights (x2)
AUX4 - Laminar lights (x3)
AUX5- Connected to 2spd port on MB
AUX6 - Landscape Lights
AUX7 - Not Connected
So, I have AUX1 and AUX7 open and free to separate my pools lights to each have their own relay. What is the purpose of AUX5 being connected to the 2spd port? Was this just an oversight and that relay is also available? Also, with the FLTR relay not connected to anything, can I use that relay for separating more lights? If not, why not, what does the FLTR relay do when using VSF pumps connected directly to a breaker?
Ideally, the pool lights and laminar lights would all be separate using 6 relays, the bubbler lights can stay together using a 7th relay, and my landscape lights would use the 8th relay.
Hopefully that all makes sense! When I started this I thought "hey, I know electronics and tech and stuff, how hard could it be", now I'm beginning to get a bit overwhelmed as some of the Pentair setup just doesn't make logical sense to me, its seems like some sort of tribal knowledge that you just "have to know". I would be COMPLETELY lost without TFP, so thanks in advance for all the help you've already provided!
