Intellicenter Time Not Working Right
setsailsoon
2,582
Stuart/FL
Folks,
I have recently installed an IPS8 system and it's working fine except it doesn't seem to adjust for DST time right. I've got it set to get the time from the internet and it's indicating an hour later than actual time. Please see the screen captures below. Time as of the last screen capture was 11:36 am. Anybody else having this issue?
Thanks.
Chris
Jimrahbe
17,097
Bedford, TX
Chris,
Since you are getting your time off the local internet why do you need to adjust for DST?? It should automatically be correct..
I'd uncheck the box and see what happens.
ajw22
16,348
Northern NJ
Chris,
Internet time synchs give you GMT and the device needs to adjust for local time zone. That is why his screen shot has him specifying his time zone.
setsailsoon
2,582
Stuart/FL
Chris,
Jim,
That's what I thought. So I left it unchecked. But it didn't change with dst so I checked auto... to my surprise it idn't make any difference. So I've with the time settings and find that the "auto adjust dst" box does nothing regardless if I set time manually or automatically in the advanced settings. I ended up setting time manually and it's correct now. But dst function doesn't seem to do anything. I pressed save after each change and it makes no difference.
Thanks for the reply.
Chris
setsailsoon
2,582
Stuart/FL
What Firmware version are you running?
r.
r,
Here's the about section:
Panel Configuration: SHARED BODY
Web Client Version: 1.042 b1 October 19, 2019
Web Server Version: 1.0.0.22
THW Version: IC: 1.023 , ICWEB:12-13-2018 0.88.37
Installation was a breeze and I consider this issue a minor inconvenience. I would like to determine if it's operator error and if not, report it so they can fix it. Is there an new version that you know of?
Chris
bdavis466
Platinum Supporter
Aug 4, 2014
5,420
San Clemente, CA
Pentair programming is ludicrous. That check box probably just adjusts the displayed time is by an hour when DST occurs. Since the box wasn't checked at the time, the clock wasn't adjusted.
Leave the box checked and when spring comes I bet it adjusts. I saw the same thing happen with my IntelliTouch and it seems that Pentair just wrapped the old programming in a new package with a wifi connection.
setsailsoon
2,582
Stuart/FL
That would make sense. Shouldn't be hard to fix but it sounds like it's been this way for a long time.
Thanks!
MyAZPool
1,206
Arizona
r,
Chris
Hi Chris,
Please see my PM regarding this.
r.
