I just replace my old Jandy with an intellicenter that has pool and combo set up.
I really like the new system however I have one item unaddressed.
In my current set up I have the spa setting to which I can turn it on and off and I can turn the heat to the desired temperature or off completely. Also I have a single speed 3 hp pump Pentair that works for both Pool and Spa.
I am trying to have it work like my old Jandy in which I was able to turn on the spa heater button and it would get the temperature up to the setting by putting warm water into the spa. Then when I was ready to get in to the spa I could hit the spa button and the Jets would come on.
There are times when you may wish to soak in a certain temperature and maintain it by having water come in at that temperature for an indefinite period of time without activating the Jets.
With the new system I cannot do this as initially set up. if I want to heat it , the Jets are on. if the Jets are off the temperature will steadily reduce based on the outdoor temperature. I should note I do not have a separate blower or any separate pump for the spa.
any advice?
any advice?
