- Dec 26, 2019
- 376
- Plaster
- Pentair Intellichlor IC-40
Question for those of you running the Intellicenter, and possibly any other Pentair automation using ScreenLogic. When you have freeze protection mode enabled, for example on both Pool and Spa circuits, the automation will toggle between the two circuits about every 15 minutes, in order to keep water flowing through both circuits. Is there a way to get the automation to do something similar on a feature circuit, where there is only one "on" position?
Let me try to explain further. I have a feature circuit (Floor Cleaner) set up for my IFCS, that actuates a 3-way valve, to direct flow through the IFCS. When this circuit is off, the flow goes through a bypass loop around the IFCS. I currently have the freeze protection selected for the 'Floor Cleaner' circuit, which will turn this circuit on, anytime the freeze protection kicks in. But this will just turn the IFCS on and not cycle it on/off to keep water flowing through both the bypass loop and the IFCS. I think this needs to be set up to toggle it on/off so that it doesn't freeze up the bypass loop, but not sure how to accomplish this.
--Jeff
--Jeff
