Intellicenter app not showing heat set point
scchan1w
Active member
Mar 6, 2019
44
Fremont, CA
I recently updated my Intellicenter firmware and I noticed that when I use the iOS app to turn on my heater in pool mode, I no longer have a menu to control the heat set point in the app. See attached pictures. Any setting I need to update due to the latest firmware? I can’t remember if the mode should say “Heat Off (scheduled)” in the app. This seems wrong. The panel is correct. Thank you
scchan1w
Active member
Mar 6, 2019
44
Fremont, CA
Turns out I needed to set the schedule to "Don't Change" on the Heat selection. Previously, I had it to "Off". I also noticed that with the new firmware, I can update the schedule on the iOS app, and it correct updates the schedule. Previously, the schedule wouldn't get updated from the iOS app.
