Installing replacement liner inside of Intex 18' metal frame
aisored
1
sauquoit
Ty for this post. It saved us from losing $400 due to getting scammed when we were sold a pool that we later found over 40 holes. I used the clips you suggested and it all worked perfectly. 1 thing we did a touch different was we added eye screws near the bottom of each leg and ran one long rope throughout the entire thing. We didnt have the tabs for the pull rope like you have and this seemed to work out great as now all the weight is evenly distributed across the entire liner, the rope and the legs.
latin_racer
92
Las Vegas, NV
Can anyone who has done this please post any update along with the finish product picture. I just had my Intex liner replaced and I already found a few minor leaks around the seams. I was extra careful but I guess Intex has issues with quality. I would like to do this next summer.
Azgirl71
Platinum Supporter
2,586
Sierra Vista, Az
There are several pictures through the entire thread. You just have to look at all the pages.
Blacklisted
244
El Cajon CA
Has anyone used a grommet kit to hold the liner in place? I picked a kit up for $5 and I think it has 20+ grommets and the tool to install them. Seems a little cheaper than getting the grabbers. I will be doing a replacement liner this winter/fall. We have a leak but so far it's manageable.
Hbah923
47
Well here is an update of the original pool that started this thread. It's been 4 years now and still holding water. I have replaced most of the tarp grabbers starting I think after the third year due to them finally weather cracking and breaking. I just bought some and would replace one when ever it gave out. The top of the liner that lays on top of the railing is the only thing that has wear on it. It has been hit by some major hail stones through out the four years and ripped and cracked it. I used Tear-aid patches to cover over them and worked great. Just doesn't look great. I am thinking about replacing the liner next year with one that has something printed on it since I know this actually works and holds up good. Still trying to think of some way to put something over the top rail that makes a cover. I guess it would be a top rail for the top rail. Lol. So for me this has paid for itself. I have a Hayward sand filter, 1hp pump (runs 24/7),intex chlorine generator (set on 7). I leave the solar cover on all the time and tool it back when we swim. I do leave it in covered every now and again to cool the water if it gets over 100 degrees. I vacuum every other week. That's all I do. Stays crystal clear and I don't have to use any chemicals at all. At the end of the season I use Algaecide 60 and cover the pool with a regular cover. Always clear when opening.
tikimike
1
Lyman,SC.
Ours is just over one year old and blew out at the bottom seam last night, Joined the group this morning and the wheels are turning. Thanks for the awesome ideas .
Jsch96
10
Neenah, Wisconsin
Bought a 24' by 52" Intex on CL and can already see some holes (but of course the ad stated absolutley no holes) and this entire thread has made me very excited for installation time next spring. I'll go with the 24'x52" standard overlap 25ml cracked glass liner on Amazon and see where that gets me. Its quite an old pool (intex liner isn't checker its little blue sea animals) but I'm sure it'll install just about the same.
injoyd
2
Fort Worth, Texas
This might not work as well on the ULTRA frame's but on the regular metal frame intex pools, for added esthetics, take water noodles and carefully cut a straight slit from one end to the other and you have a perfect soft top rail on your pool. This is also the only thing you need to hold the liner in place, if you do it right. This should be the last step in adding a liner to your metal frame above ground pool. You're welcome
Reactions: Cookie Monster NJ
injoyd
2
Fort Worth, Texas
Hbah923
47
Yea I don't think it would work on the ultra frame but would be awesome on the regular type frame. It would make it look pretty cool. As long as the kids don't take them off and play with them. Hahahaha. I would probably still tie the line down just for peace of mind.
Blacklisted
244
El Cajon CA
Got pictures of this way of doing it? I like the concept.
