I recently installed an SWCG (Camilar CMARSHA40-3Y after seeing a good deal at $625), and it's working so well that I've forgotten about the Stenner pump I was using I have a 15-gallon drum with about 8 gallons of 12.5% liquid chlorine, and the question is -- is there any reason I can't just turn off the SWCG and inject from the Stenner (at appropriate rates of course) in front of the SWCG? I'm guessing the SWCG doesn't care if higher chlorine water is flowing through it (like it would if I was injecting acid), but thought I'd check.
I did add another tee after the SWCG with plans to eventually inject acid after, but I'd rather not move the injection point right now.
