I recently moved to AZ and purchased a home with a pool. The home and pool are fixer-uppers.
POOL SURFACE:
The pool had multiple cracks in the surface of the pool and the fake rocks around the edge of the pool. I drained the pool and am having it resurfaced/repaired now.
EQUIPMENT:
Pumps (one for pool, and another for water feature/ grotto)
There's my brief summary. I'm very new to this all and will be asking multiple questions in different sub-sections shortly. Thank you in advance to anyone who responds to any of my posts.
POOL SURFACE:
EQUIPMENT:
- The pump for the grotto was seized and wouldn't turn on. I removed the motor and took it to a pool store and bought a replacement motor and got it install. Now both of the pumps run!
- Cartridge filter: The previous owner replaced the lid to the filter container with a larger lid, which means the cartridges do not seat correctly when the lid is closed, so they used a ratchet straps to hold the smaller filters down inside the larger container. ugh. I am now trying to figure out what filters I need to purchase to fit within the container.
- There is a timer toggle switch inside my junction box that's falling apart. I took it out to get the part number, but there's a warning on the back that it's for indoor use only so I need to find something else. There are two mechanical pool timers, but only one it currently connected to the pump for the pool. Can I remove the little nubs that determine when the pump is to turn on and off and just use the manual override to turn on the water feature when I want to use it?
- Pool light. The cover of the pool lamp is loose (only being help to the wall with a single screw. It won't turn on but the GFCI outlook also seems to not be working so I'll replace that first and then investigate on the light.
