Indoor Pool | Pool Heater
calculus
10
Florida
Hi,
I have a small underground indoor pool, 14k gallons.
I want to find the best energy efficient way to heat the pool. The water is always cold. Any suggestions?
ajw22
23,724
Northern NJ
Pentair Intellichlor IC-60
What fuel sources do you have? Nat gas? Propane? Electricity?
Where will the heater be placed?
Please create your signature with details of your pool and equipments so we can understand how your heater needs to fit into your existing system.
calculus
10
Florida
Fuel sources: Propane and Electricity
The heater will be placed outside.
ajw22
23,724
Northern NJ
Pentair has a Heat Pump Calculator to determine the appropriate size Heat Pump for your location. Pentair seems to do honest calculations based on the physics and efficiencies of each type of pump and energy source.
To get the most accurate cost comparison you should change the default electric kwh, natural gas price, and propane price to actual prices in your area.
Raypak has a Gas Pool Heater Sizer. It tells you the Temperature Rise/Hr and Natural Gas and Propane costs to heat a pool in your local area to selected temperature by month. Adjust the natural gas cost and propane cost in the lower left to your local gas prices for accurate costs.
