Indoor pool cover
Pete Ernenwein
1
canastota ny
What is the proper cover for indoor pool. Pool is heated. Need cover to keep heat in and of course control evaporation. Have used solar covers with air bubble I guess for flotation. Have problem with water getting on top of cover which increases evaporation. Occurs mainly around jets due to agitation. Is there a better material.
ajw22
11,223
Northern NJ
Welcome to TFP.
There are retractable covers you can install. I think any floating cover will get some water above it.
The higher your air temp is over the water temp the less evaporation you will get.
