Greetings.
I have just had a pool installed and have a question regarding the operation of the heater pump.
The heater unit has a separate pump and pipework installed, and appears the small pump is setup to run 24/7 and the heater unit comes on when required.
How do you normally run a setup like this? Running the 1hp 3 amp pump 24/7 will use more electricity than the heater unit itself. The heater is an inverter type.
Should I install a timer and turn off the pump at night? Therefore only letting the heating occur during daylight hours? Or is 24/7 recommended. Running cost of the pump being the main concern.
Thanks
Thanks
