Increasing ph with returns
jimim
2,011
NE/Pa
Hi guys. I added some cya a day ago cause it went down cause I by mistake took 5 inches of water out of my pool vs 1 inch.
I’ll give everyone a minute to laugh.
Ok so I added the cya (2 lbs). It dropped my ph to 7.6. I want to get it back up to 7.8 cause my csi is now -.44. If I get back to 7.8 I’ll be at -.33 which I would assume is safe enough due to the fact my ph is in the tfp guidelines. My fc is 7.5 right now when I did tonight’s reading.
I turned my returns up last night so 24 hours later no increase.
I have 3 returns turned up with pump on 3000 rpm.
I read to increase ph when it is very low it will increase quicker than if u are already in the 7’s and want to increase it a little.
Was just looking for some advice.
Luckily I only threw off my cya and ch a little.
ajw22
4,462
Northern NJ
My advice is relax. CSI of -.44 vs. -.33 will make no differnce. Especially for a few weeks. The pH will rise naturally and the water will be warming up.
jimim
2,011
NE/Pa
Ok cool. As you prob know by now I’m a worrier. It’s more because I’m riding that fringe of the -.3 already. Just don’t want to etch my plaster cause I ride in this negative range all season to prevent any scale in the pool or swg.
ajw22
4,462
Northern NJ
I don't know where you got -0.3 as any hard lower limit. Etching doesn't happen until CSI below -0.6 for many months. Scale should not happen if you maintain a negative CSI. So you have a pretty wide range to work with and short excursions lower are no big deal.
Warmer pool water will fix your CSI in a few weeks.
Jimrahbe
11,450
Bedford, TX
Jim,
My guess is that your pH will be back up to 7.8 by the time you read this.. :mrgreen:
I agree with Allen... Sit back and relax...
CSI between +.6 and -.6 is ok... it is just better to run between 0 and -.3...
jimim
2,011
NE/Pa
My salt generator isn’t on yet so no it won’t be 7.8 yet. Lol. Once that goes back on I feel like the ph goes up hourly.
Ok thanks for the education. I appreciate all the help. I’m still learning here. I think I’m getting better at least.
Other Threads of Interest
