🤦‍♀️ In a pinch what solid chlorine tablets would be Safe to use occasionally with my liquid pool chlorine (10%)
Dba1047
Active member
Aug 10, 2019
44
Bayonne,NJ
Trichlor?
i m having real issues finding liquid pool chlorine and assume it will only get worse as the season progresses .
is it safe to use trichlor occasionally as an alternative to my liquid chlorine ?
Tu
mknauss
42,150
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Just monitor your CYA level by testing and adjust your target FC accordingly.
Many are find plentiful supply of liquid chlorine. Do you have an Ocean State Job Lot store in your area?
Dba1047
Active member
Aug 10, 2019
44
Bayonne,NJ
Nope
Everything around here is sold out
Or has not stocked for season yet .
Home Depot/ Lowe's /Walmart /Leslie pool /
Costco/ local Pool store 🤦‍♀️
DeanP66
1,229
San Jose, CA
Have you looked for regular bleach on the washing aisles of stores? Just don't use Clorox because it now comes with extra additives that you don't want in your pool. Nothing with scents either. Just plain old bleach. It's usually around 6%, so you'll have to use more to get the same effectiveness, but you may be able to find some.
