Until yesterday, I had a single stage pump and a Pentair iChor 30 wired to an Intermatic mechanical timer. No problem. Pump and SWG came on together and life was good. Yesterday, I upgraded my pool pump to the Pentair SuperMax VS 1.5. The technician that made the installation wired the pump and SWG independently. The pump is wired to a power source so that the internal timers work on the pump but the SWG is still wired to the Intermatic. Two different sources, two different time schedules.
The manuals say that these must be wired so that they come on and off at the same times. What happens if the pump fails to come on for some reason and the SWG comes on as scheduled because it is wired independently? Chlorine gas build up and a possible dangerous situation is what I see according to the Pentair manuals. What if there is a 3 hour power outage before power is restored? The pump resumes it's normal schedule (it has a memory function) but the Intermatic is now 3 hours late and is running with a pump that is shut off. Same bad outcome.
I called the installing company today and they didn't seem so friendly about the situation. I don't want to fight with them. I just want the systems wired correctly. They said it's fine even though I spoke of a couple of scenarios (above) that could be a serious problem. I need some help so that I can speak intelligently to the equipment installers. What should I tell/ask them? What do I need to know? I don't like the current wiring setup. What say you?
Thank you.
Thank you.
