I'm so lost with this algae Crud! HELP!
Waltheraustin
Active member
May 21, 2020
35
Clyde TX
That's what i buy when it's available but we are still limited if it's available. The pool is looking less green today. I have the PH back under control. All of the chemicals looks like they are in range except the chlorine which is high on purpose. I can almost see the bottom of the pool and the green is more of a blueish so i'm hopefully i found the issue with the PH. Looking for the new testing kit!
Waltheraustin
Active member
May 21, 2020
35
Clyde TX
Not sure, the tester showed it was high. 4 cups of muratic acid and I'm doing much better. Green is gone. Still a little cloudy but it's improving quickly
Waltheraustin
Active member
May 21, 2020
35
Clyde TX
This update was a few days ago. It's perfect now! Just needed a pH fix
