I have had a really difficult time with my PB. This particular issue involves the IFCS and the normal pool returns.
This is a rectangular 16000 gallon pool. One Venturi skimmer, 3 returns, and 6 in floor cleaning heads installed on the steps and shelf.
They have sent 3 different plumbers out because they suspected there was an "issue" but in the end decided everything was fine. I never asked them to come out and they were very vague on what they were looking at. This made me suspicious.
I have been checking it over and it seems that they turned off the valve to the normal returns because otherwise there is not enough pressure to run the in floor cleaning heads. When I open the returns back up, the pressure in the floor system drops to around 10 but I believe manufacturer calls for 17-22.
I have a TriStar VS900 and my investigation was done with it running at 90%
My question is if there is even a problem here? Should the pump be able to run IFCS and returns simultaneously? Do I have to choose one or the other?
Pictures attached.
I appreciate any advice.
Pictures attached.
