- Sep 8, 2018
- 58
- Vinyl
- Pentair Intellichlor IC-20
So I have a new pool install and had a couple chemistry questions.
Current:
FC 5.0
CC 0.0
pH 7.5
TA 80
CH 120
CYA 70
Salt 3000 (Test strips) (Adding salt later today)
Equipment is Pentair IC40, MasterTemp heater. In Ground Vinyl lined 10,000 Gallon.
Per the TFP CYA chart, I think my numbers look good.
Looking into it a bit more, and both the heater and IC40 manuals specify 200-400 as an ideal range for CH, with 150 being a "minimum" for the heater. The heater also lists a maximum FC of 5.
Two questions.
1) I assume that the CH "ideal" is for "most" or "average" pools and tries to account for all pools. My CH in a vinyl pool can't really be "too low" can it? Should I increase CH anyway? I have a stone paver patio surrounding the pool, but nothing that's in constant contact with the water.
2) Per the CYA chart, my FC target should be 5. Is this just Pentair being overly cautions listing that as a max FC level in the manual?
Current:
FC 5.0
CC 0.0
pH 7.5
TA 80
CH 120
CYA 70
Two questions.
