Moved from here.
Does this solution also apply to the IC40? I am experiencing same exact issue. In addition, after holding "More" for three seconds and all percentage output LEDs flash green which I have interpreted as a bad flow switch or bad thermometer.
Also, would you recommend the Pentair Aftermarket flow switch from Pool Supply Guys for $49 plus shipping. I am cheap an if I can save 50 I want to.
IC40; Sand Filter, Heat Pump, Easy Touch, ScreenLogic App - All Pentair.
