- Oct 10, 2022
- 32
- Plaster
- Pentair Intellichlor IC-40
Hello TFP forum,
First time poster and a general newbie when it comes to pool plumbing. We have in ground pool/spa (about 15k gallons) with a Pentair system (variable flow pump, 4 cartridge filter, Intellichlor 40 chlorinator). Long story short, our IC40 was shot and I replaced it with another Pentair IC40. It was about 3 years old and had the service light on (no chlorine was being produced even though we had been cleaning it on a regular schedule). After installing the new IC and powering back up system, all appeared to be working fine on the pool setting. Normal flow back to pool (with some to spa for spillover) and our chlorine, salt, and other numbers were all as expected. All readings on the IC are green and no errors noted from the Pentair panel. Running the heat for pool also was normal.
Here’s where my issue is. When I enabled the spa yesterday (this is about 2 weeks after installing the new IC40), when the return and suction valves get to about 1/2 rotated, water starts gushing (more like high pressure streaming) from the inlet side of the IC40. I immediately disabled spa and everything returns to normal. Flow to pool is normal.
I did a quick test to verify flow to the spa by powering down system, manually actuating the suction/return valves to the spa position (my layman’s understanding is all returns are from spa and all suction is from spa), and then started system with pool pump RPM set to about 1850 RPM (not high SPA RPM which is set at 3150). In this setting, flow is to spa seemed to be working normally with no flow to pool. However when I ramp up pump RPM, same thing happens - water starts gushing/streaming from IC on the inlet side.
I’m obviously not a plumber but I seem to be missing something easy here.
Sorry for the long post - any advice you can provide would be immensely appreciated.
Respectfully,
Tony C.
Respectfully,
Tony C.
