IC40 and low flow light with pump off
domshort
10
la vista, ne
Moved from here... IC40 and low flow
While my situation is slightly different, I just want to make sure I’m understanding what I think I am about the ic40 swg. Mine isn’t wired to a separate breaker so I can’t turn off. I do like to set my pump to turn off at night, however, which of course sets off the red no flow light. Does this hurt anything with the SWG having the flow light on or is it merely not producing chlorine when it is on (which I am ok with)?
Jimrahbe
15,866
Bedford, TX
Jen,
If your cell shows a no flow light with the pump off, it is not wired correctly.. When the pump is off all power must be removed from the cell's power supply... This is because it is possible for the cell to explode if the cell has power with the pump off. Granted, it does not happen all the often, but it does happen as proven here, several times...
domshort
10
la vista, ne
Actually I do have another question. Per the OP he wanted to run the pump rpm’s lower that what is needed to keep the flow light from turning on. If I keep the pump on at night but at a very low rpm (flow light will come on if under 1800rpm) is this adequate to keep the salt cell from risk of exploding?
