IC20 Red Low Salt
Soccernutt10
10
Saint Louis
I am working on my in-laws pool at the end of last year their low salt light was red. Since it was still producing chlorine he left it alone and would throw a bag of salt in Every once and awhile. This year upon startup its red again and after doing research I replaced the flow switch. Upon initial start up after replacement the IC20 went through the red green flashing sequence then settled on green salt light. After a few hours the red low salt light retuned. I added some more salt and let it set a few days and rechecked it. It still had a red low salt light but everything else was still green.
When I tested the water there was zero chlorine And the salt level was fine which got me searching again. This was a replacement cell for a original unit with a 3/09 build date and their IC20 only has a small box attached to the wall near the filter. The cell that I’m working with now has a build date of 07/2016 so I’m wondering if it’s a board that’s gone bad as it seems not to be producing chlorine and still has the low salt light While the other lights are green.
ajw22
18,959
Northern NJ
Reactions: Soccernutt10
Soccernutt10
10
Saint Louis
Welcome to TFP.
When a SWG indicates low salt you have to independently test the salt preferably using the K-1766 Taylor Salt Test or Salt Test Strips - Aqua Chek
Only once you know the actual salt level versus what the IC20 is saying can you begin diagnosing the problem. A failure of the temperature sensor in the flow switch will give incorrect salt indications.
See Pentair Intellichlor ICXX SWG - Further Reading for how to display the temperature the cell thinks the water is.
I took it up to Leslie’s Pools and had it tested. They told me it was high in salt. I had added more thinking it was an accurate reading.
Pentair IntelliChlor Power Center Surge Board 521034Z
ajw22
18,959
Northern NJ
We don't put a lot of faith in the accuracy of Leslie pool tests. The actual salt level helps in the diagnostics. The IC20 does not shutdown due to high salt.
Check the temperature sensor in the flow switch.
Jimrahbe
18,239
Bedford, TX
10,
I really doubt that the Surge card has anything to do with the cell's red and green salt level lights, but it is the Cell's power supply..
The surge card supplies about 40 volts DC to the cell. You can measure it with a voltmeter. It might be possible that the DC voltage is low, but normally this will cause the cell to just shut off.
When the cell is working, the voltage will be about 35 volts, when the cell is not generating chlorine the voltage is about 39 volts.
Soccernutt10
10
Saint Louis
how do I do that? When I press and hold the more button all the light flash and when it’s done it ends at 20% when I press more again it’s at 60%. The thermometer hanging from the pool ladder says it’s about 65.
Soccernutt10
10
Saint Louis
10,
Where do I measure this?
mknauss
30,916
Laughlin, NV
Your picture shows the IC sensing low salt (less than 2600 ppm). Test your water with a K1766 salinity test kit. Let us know your results.
Soccernutt10
10
Saint Louis
I had it tested at Leslie’s and it was high. When I Re-installed the old cell after it ran through its sequence it showed that the salt was high too.
they were out of test strips when I was there I have some coming from amazon.
Jimrahbe
18,239
Bedford, TX
10,
What does that tell you? The old one works, the new one does not, and swapping the flow switch did not help???
Soccernutt10
10
Saint Louis
10,
I wanted to rule out the power supply board and confirm the high salt reading that Leslie‘s told me.
No swapping the flow switch didn’t help. Still low salt and no cell light on.
