iAqualink LED color change not working
Pool$
24
Placerville, Ca
The iAqualink app is no longer giving the option to change the color on our spa LED's. The pool and spa lights are controlled separately on the app and we used to get a popup asking what color you wanted when you toggled the lights on and off. Then a couple weeks ago, the popup stopped and you could only turn the lights on and off. Then randomly today, the pool color started working again. The spa is stuck at one color.
This is a new system we had installed this summer.
Advice?
ChristopherDB
In The Industry
Apr 21, 2021
95
Florida
Jandy Aquapure 1400
Go to Menu > System Setup > Color Lights > Select the brand of lights you have > You'll then see a list of all your Aux ports. There should be two letters to the right side listed next to the name of your light. If not, tap on the light name and then the two letters should appear. For example it would say JL for the Jandy lights. Then tap save. Exit out and then when you turn on the light you should get the pop-up to select the colors.
Reactions: Pool$
Pool$
24
Placerville, Ca
This fixed it!
The pool had the wrong light type and the spa was blank.
Thank you!
mknauss
44,842
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
This fixed it!
We are glad you have found our information helpful. Please, if you can, consider making a donation to TFP. We are staffed by volunteers and are registered as an IRS 501 (c) (3) charity and donations are what keeps the forum operating without advertisements.
Support TFP!
