iAqualink App Options
Ukiwis
52
California
Thanks @PoolGate. I was like "how do I do that?"...so was looking around and noticed the other 2 tabs. Of course the "Jet Pump" is on the "equipment" tab and I can simply turn it off/on directly from there. Amazing that I'd never put two and two together. Thanks.
Reactions: PoolGate
Ukiwis
52
California
@PoolGate On my OneTouch tab there is a "Clean Mode". If I use that button the filter comes on. If I turn "Clean Mode" off and use the filter button directly "Clean Mode" does not turn on. How do I see what "Clean mode" actually does that's different to the Filter option? Is there a programming guide somewhere I can reference?
TIA
KIWI
PoolGate
4,694
Damascus, MD
TIA
KIWI
It is probably a "OneTouch" macro. If you go into your Aqualink setup, you'll open that and look at what devices are being used.
Reactions: Ukiwis
