HI all,
So landscapers are coming next week and have an awesome plan in place thanks to all of your suggestions, we have the testing kit (the big mama jamma T-100 XL or something like that ha ha ha), all the recommended chemicals (not too many) etc. some gadgets (the wall mount skimmer) I have a few questions/recommendations needed.
1) Eventually I will be getting a 3/4 deck installed around outside (next spring project) but for now, I hear the stairs provided are not sturdy. I have a 6'5" 295lb BF and 21 yo, 18 yo and 10 yo boys.... what do you recommend? and should I purchase the pad that the stair legs sit on? We DO NOT HAVE any decking or anything around it so would need the stairs to be both inside and outside of pool.
2) I only have the filtration system that came with package included 110-120V Sand Filter Pump & Saltwater System (pump flow rate: 2,650 Gph) with Hydro Aeration® Technology for easy maintenance. I have not decided if I should transfer to salt (i understand a chlorine pool IS a salt pool) but if I do, what other filter/pump do you recommend?
3) sand for filter- silica #20 approx 70lbs??? Correct??
4) once I fill- I do not put anything into pool. I test and then input the numbers into the app (I paid for the better one) but also place them here? I am so nervous about the chemical aspect as I was a competitive swimmer for 15 years and shocks and chlorine dumps were regular :/. Looking forward to having a clean pool with the minimal amount of chemical (I don't mind putting in the work)
I am sure I will come up with more as I want to do this right the first time. Spending a small fortune on landscaping/leveling so it NEEDS to be done right ha ha ha
