I think I have algae. I know I have tons of water boatman
lascas01
48
Pearland TX
103793
So I have a problem. We thought this was sand but highly doubtful. It poofs as soon as you touch it but it feels slightly gritty
I have a ton of the water boatman now too
My pool chemistry as of today is( I have fiberglass 15000 with swg)
FC 8
Cc 0.5
CA 250
TA 60
Ph 7.5
Salt 3970
Last week did OCLT test and didn’t lose any chlorine (10 and 10)
Live in Texas. Lots of sun and high temps
We are getting a new pool filter hopefully this weekend
What other suggestions do you have
I am going to increase my chlorine levels and most likely start slamming will also increas my TA
I have been battling this early May. Every time I think I have won those Dang bugs show up again!!!
I have attached the best pics I could take of my two culprits
Thank you for any and all advice!!!
Oly
1,839
Fresno, CA
The boatmen are amazing swimmers. I don't want them in my pool but they are good guys in natural pond systems.
Reactions: lascas01
sacredcow
155
Houston, TX
I'm on the north side of Houston (approximately Spring, but still Houston address), and I also have had the water boatmen show up in my pool this spring, even though the water is balanced and at the higher end of recommended chlorine for the CYA most of the time. I shocked with calcium hypo (the rain had pushed my CH below 250) a couple of weeks ago and they haven't come back (knock on wood).
Reactions: lascas01
Oly
1,839
Fresno, CA
Only use the Cal Hypo if you can handle the expected rise in calcium.
Pollen and insects cycle out as the season progresses.
lascas01
48
Pearland TX
Calcium is a bit in low end of normal. I have fiberglass so I am not sure what to do
Suggestions??
These suckers bite so I would like gone!!! My daughter hates them!!!
Oly
1,839
Fresno, CA
Put your daughter on the end of the leaf net and make a game of chasing, catching and removing the boatmen.
Use the Pool Math calculator to determine your current CSI (calcium saturation index) and use the Effects of adding chemicals calculator near the bottom to estimate the impact of adding a known amount of Cal Hypo.
You do not have to guess what will happen when adding chemicals to your pool water and with the TFP method you are always in control.
Reactions: lascas01
lascas01
48
Pearland TX
Ok. Will do. She hates the bugs!!!! She leaves that for me!!! Lol.
I appreciate all your advice. I am still learning and trying understanding all of this.
lascas01
48
Pearland TX
Ok. I have sand like junk on the bottom of the pool and tons on water boatman
Chemistry right now
FC 9.5
CC0
Ph 7.5
CH225
TA 50
CYA50
Water temp 84
SALT 3400
15000 fiberglass pool with SWG
Pool looked good this morning and now a bit hazy. Did OCLT test last week and we passed
I know my TA is a bit low and will be fixing that now
Just curious if phosphorus could be my issue and why I can’t seem to get rid of that yellow sand looking stuff ( probably algae. Ughhh)
Yes I have brushed pool. Can’t do daily with my work schedule etc.
Any other suggestions
mknauss
37,085
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Phosphorus? I assume you are thinking of Phosphates.
Phosphates are algae food. TFPC eradicates the algae, so no need to worry about phosphates.
You need to run a SLAM Process to completion.
lascas01
48
Pearland TX
Sorry nurse here. I deal in phosphorus more than phosphates lol
I have kept my FC at 8 or better with CYA of 50 for over 2 weeks
I don’t have any CC and we passed the OCLT. I believe that means I have completed my SLAM???
What did I miss ???
mknauss
37,085
Laughlin, NV
Fiberglass
You are not at shock level for your CYA and thus not following the SLAM Process protocol.
First criteria for a successful SLAM is crystal clear water. If you have algae, even dead algae, in the pool, the water is not crystal clear.
Raise your FC to 20 ppm and maintain that until your water is crystal clear.
Oly
1,839
Fresno, CA
A SLAM for a CYA of 50ppm means a FC level of 20ppm sustained. You need to bring the big guns.
