I just don't get it!
mikey51
10
Okay, I never said I was smart! the Taylor K2006 FAS-DPD kit just confuses the heck out of me. I don't even know if I am doing the Chlorine test correctly. I fill to the 25 mL line,add 2 dippers R-0870, turns pink, then began to ad R-0871, put in 9 drops no change at that point so I stopped to ask you folks. Does it really take more drops? Also did CYA test and did not even come to 100 reading.
I was successful with Ph test . I also tested with a Chlorine and PH with a Poolmaster kit and HTP kit, on both Ch was 2-3 ppm and ph was 7.4. What am I doing wrong with the Taylor kit? Your help in testing would be Really appreciated. I think I'm trainable. Thanks Mike
PS. Sparkling Clear, no apparent issues. New pool may of 2010
dmanb2b
3,734
NY
Welcome...the 25ml sample tests FC in 0.2ppm increments. 9 drops would only be 1.8 FC. You need to keep going and I would suggest using a 10ml sample instead (measures in 0.5ppm increments) to save reagent. On the CYA...that's a good indication it is above 100. Try diluting your pool water 50/50 with tap water and repeat the test, then just multiply by 2.
mikey51
10
Thank you.. I will get the hang of this! Also, I'm guessing the dipper powder should be level not heaping scoop. I just dipped into Bottle dry and it came out level scoop.
Bama Rambler
23,047
It takes as many drops as it takes to turn it clear. Remember that you're only measuring .2ppm with each drop in the 25ml test, so just an FC of 3 will take 15 drops. It's 5 drops for every one ppm of FC. Also remember that it's not a gradual change either. One drop it's pink the next drop it's almost completely clear.
If a few drops in the cya tube completely obscures the black dot it means your CYA level is very high. You'll need to drain and refill at some point to get it to a measurable range.
Just saying the same thing as the Dman was. :-D only slower!
mikey51
10
I need slow!! :0 Thanks. And yes reading bottom up on the tube it took about six drops to hide dot, did not reach first level line of 100. Slow is good ;)
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
31,713
Mike,
You switched tests! Now you're talking about the CYA test. Master the procedure for one test and then go to the next one.
mikey51
10
True I am talking about both tests. But I am satisfied at the moment with Chlorine and PH since I can get decent results with the other 2 kits. It is the CYA that concerns me since the pool has only been in since May.. Thanks everybody for helping!! I'll need much more and it's appreciated . Mike
