I have to replace my liner. I was wondering how hard it would be to add an overflow drain during the process. I assume you can do this through the skimmer?
A 1" hole I'm the skimmer at max water level, usually am inch below faceplate top. Then a male adapter, gasket, amd nut. Some skimmers have a knockout already for a 1" glued fitting, you gotta look carefully. Then that line runs downhill. Depends on what type of decking you have as to how easy it is to do
